This is an unusual question but maybe somebody else has had the same experience. I am doing a mini truck brake conversion and am using the original bolts to bolt the spindles on...I have the order right...seal, gasket, backing plate, spindle, gasket and then the hub. Well, the bolts only tq to 30lbs and i get real nervous because i can keep turning them with the feeling of it stripping around the corner. One bolt sheared under force. all threads looks great though. Would bolts a little longer help you think? I have room for another 1/4" of thread. It can't be that the threads are bad because as i said they look fine and this is consistant with all holes. Any ideas?
