Should used spider gears be kept with the side gears they have broken in with? I'm changing to fine spline axles and picked up a set of used side gears and spiders. When I got the old ones out, I noticed that the faces of the old spiders are in better shape than the ones I got with the fine spline side gears, (pitting on the faces). The side gears faces look fine, so I'm wondering if I can use my old spiders with the "new" side gears. The side gears don't look like they have much of a precision fit. FYI, I'm running a stock 155hp F motor.
Also, the pinion shaft spacer I got with the side gears is really loose on the pinion shaft, like 1/16th" bigger bore than the pin. Is that normal? I'm swapping my old front diff to the back (I put in a later front axle) and I haven't pulled the old one rear out yet, so nothing to compare with, and btw this is my first diff - forgive my noob questions.
Oh, one last question - the spider gear spacers (or thrust washers?) on my new set look like steel with holes all the way through. The oldies are copper with dimples in the cupped side. Any preferences?
Any general warnings? (except don't break the lock pin!?)
Thanks!
Thanks!
