Spicer® 1350 Series Driveshafts Now Available for The Ultimate Dana 60™ Axles
Products Provide Enhanced Reliability for High-performance Applications
LAS VEGAS, Nov. 1, 2016 – Today at the 2016 Specialty Equipment Market Association (SEMA) Show, Dana Incorporated (NYSE: DAN) announced that it will now offer Spicer® 1350 Series driveshafts for The Ultimate Dana 60™ axles for the Jeep® Wrangler JK.
“These new Spicer driveshafts are the perfect match with our Ultimate Dana 60 axles for the Jeep JK vehicles, with their high horsepower and torque applications and larger tires,” said Doug Wolma, vice president and general manager, Dana Aftermarket Group. “Spicer driveshafts are renowned for their performance and durability in exceptionally harsh, high-performance applications.”
The Spicer® 1350 Series driveshafts are designed as a bolt-in replacement for the original equipment on both 2-door (front only) and 4-door (front and rear) models. The driveshafts feature a Spicer Life® Series 1350 u-joints and a longer slip length of 6 inches. The slip assembly is located at the transfer case next to the double carden joint to minimize damage and contamination. The driveshaft is constructed with an outside tube diameter of 2 inches, for optimal clearance, and a tube wall thickness of .120 inches for enhanced strength and durability. It comes with a new Spicer® 1350 series transfer case yoke and connects directly to the Spicer® 1350 series yokes on the UD60 axles.
The Ultimate Dana 60™ axles, introduced at SEMA 2014, are bolt-in replacement upgrades for front and rear axles on the Jeep Wrangler JK. The axles feature:
  • 35-spline, SAE-4340 nickel chromoly steel axle shafts designed for higher torque, larger tires, and demanding off-road applications;
  • A greatly enhanced carrier with Spicer® performance ring and pinion gearing;
  • Optional ARB® Air Locker® or Eaton® ELocker® for improved traction at the flip of a switch;
  • Massive SPL® 70 u-joints, exclusive to Dana;
  • Full-float design for greater load-carrying capacity; and
  • Upgraded, heavy-duty brakes with plug-and-play ABS.
Dana will highlight a number of new products at its SEMA Show booth, No. 36097, located in the South Hall Upper at the Las Vegas Convention Center.
More information about the Spicer® 1350 Driveshafts for The Ultimate Dana 60™ axles is available at www.SpicerParts.com?utm_source=rss&utm_medium=rss, or by calling Dana Customer Service at 1-800-621-8084.
About Dana in the Aftermarket
Powered by recognized brands such as Dana®, Spicer®, Victor Reinz®, Glaser®, GWB®, Thompson®, Tru-Cool®, SVL®, Magnum®, and Transejes™, Dana delivers a broad range of aftermarket solutions – including genuine, all makes, and value lines – servicing passenger, commercial, and off-highway vehicles across the globe. Leveraged by a global network of 13 distribution centers, Dana’s dedicated aftermarket team provides technical service, customer support, high fill rates, and on-time delivery to customers around the globe. For more information, please visit www.dana.com/aftermarket?utm_source=rss&utm_medium=rss.
About Dana Incorporated
Dana is a world leader in the supply of highly engineered drivetrain, sealing, and thermal-management technologies that improve the efficiency and performance of vehicles with both conventional and alternative-energy powertrains. Serving three primary markets – passenger vehicle, commercial truck, and off-highway equipment – Dana provides the world’s original-equipment manufacturers and the aftermarket with local product and service support through a network of nearly 100 engineering, manufacturing, and distribution facilities. Founded in 1904 and based in Maumee, Ohio, the company employs more than 23,000 people in 25 countries on six continents. In 2015, Dana generated sales of nearly $6.1 billion. Forbes Magazine has again selected Dana as one of America’s 100 Most Trustworthy Companies for 2016. For more information, please visit dana.com.
The post Spicer® 1350 Series Driveshafts Now Available for The Ultimate Dana 60™ Axles appeared first on RockCrawler 4x4 and Offroad Magazine.
Related posts:
  1. Dana Announces Ultimate Dana 44™ “What’s The Diff” Axle Give-Away Contest Winners
  2. Dana Adds Ratios to Spicer® Ring and Pinion Gear Offerings for Dana 44 and Dana 60 Models
  3. Dana Introduces Spicer® Performance Spools to Deliver Maximum Traction
Continue reading...
