I am testing my speed sensor per the FSM. When I apply 12v power to it, it shows voltage, which constantly changes, without spinning the shaft. The FSM says the voltage change should occur with shaft rotation. I found a used sensor, and it does the same thing, so I don't know if I have two bad sensors, or two good sensors. BTW, my speedometer stopped working, so I am trying to figure out if this is the problem, before I remove the dash. Any thoughts?
