Speedometer question
Qld Australia
Hey guys I'm chasing an instrument cluster from a later injected 4500 twin cam, mostly as I need the tacho internals. This had me thinking though if I get a fully functioning cluster then I get the electronic speedo. I know there is the trigger module that bolts into the gearbox but if I want to convert to the later set up what else do I need to get. Is there a special part fo the loom and other ECU type bits or can I wire the gearbox sender straight to the speedo somehow.
Mine is a 90 model diesel so I? doubt I have any of the compatible loom that would be used.
