Speedometer not working on my "75 40
If you have a cordless (or not) drill detatch the speedo cable at the transfer case. With someone watching the dash hook the drill to the cable and give her a spin. If the speedometer moves you've eliminated the guage and cable as problems. Pull the gear.
Have you looked at the condition of, and verified that the cable itself works, as it should?
I would not be thinking about removing the drive gear from the t-case, but rather, verifying that the cable is not broken, and functions properly...
Again-
Has this ever worked? Did it just die today? Did you ever have your stereo turned down enough to realize if the speedo head or cable were possibly making any noise before it stopped working? A little more info may help with this...
1-Remove the negative battery cable.
2-Remove the two screws that hold the instrument cluster in place.
3-After pulling the cluster forward a bit, unhook the speedo cable from the back of the instrument cluster, by squeezing in the little catch, and pulling it off.
4-Unhook the cable from the drive mechanism on the transfer case, and turn the little round piece that is inside, or, see if it falls out, which would indicate the need to replace the speedo cable, if it does turn, and does not fall out, have someone verify that the other end of the cable is turning up in the cabin.
If the cable is functioning as it should, then the focus should turn to either the drive gear in the case, who's operation can be verified by jacking the rear of the truck up, supporting it on jack stands, chocking the front wheels, placing the transmission in neutral, and turning the rear drive shaft by hand and watching to see the little female drive piece inside the area where the speedo cable attaches actually does turn.
If this operation occurs, then I would say that it is a pretty safe bet that the speedo head is not functioning properly, and may need to be repaired, or replaced.
Good luck!
-Steve
Steve and I are in cohoots to confuse you :D .
Seriously though, I should have added that when you spin the cable if nothing happens you've narrowed down "a" problem to the the cable and speedo. I would spin the cable before removing the dash. If nothing happens do excactly as Steve says. If you have the back of the truck raised when you first go under the truck you can check the gear (as Steve mentioned) at the same time you're checking the cable. Don't leave us hanging, let us know what you find.
What part of TEXAS?
N. East here
Chris
ok but what if it worked fine and then all of a sudden started jumping back and forth? I have already bypassed the speed sensor and the cables are pretty new(summer)
I get above 20mph and it starts jumping all the way to 50+ and then back down.
Also the milage isn't moving anymore.
Thanks and sorry for hijacking
Poser....Very good info for my Saturday project. Thanks.
Quazii- I am in Tyler 3 or 4 days a week and Greenville the rest of the time. You'll see me running about 60 mph down HWY 69 in my primer/mustard color 40. Honk or shoot me the finger some time when you pass me in your FZJ-80.
My '75 did this and it turned out to be the cable. It was broken midway to the speedo. The frayed ends where it broke would grab each other and turn the speedo head unit at slow steady speeds, but as I accelerated, the frayed ends would slip and then catch in an irregular fashion. The speedo needle would jump around from 0 - 80. Replaced the cable and all is good now.
I would think that a worn gear would do the same. The teeth catch sometimes and skip others. If you have already replaced cables and the milage isn't turning when the speedo is, then I would look to the gears in the head unit. Also make sure the cable is fully engaged into the back of the speedometer.
