speedo q's
is there supposed to be a plastic gear inside my transfer case, that drives the speedo gear (metal) that drives the speedo cable? if so what's it called
is it plastic? cause i think i still got a steel one in there that looks like that, it's just gunked up with melted plastic...
like, what is part number 86?
i gotta look closer at mine then oops... i thpught that the gear was metal, and there was just gunk on it...
could a busted rear output shaft bearing cause this to melt... and could a busted rear diff pinion bearing, driven for long periods of time, trash the output shaft bearing? trying to CSI the transfer case meltdown
