Speedo needle jumping around
Dallas, Texas
OK, I have the truspeed calibrator in my cruiser. Recently it has begun jumping around up and down. Any ideas where to trouble shoot. The speedo cable near the Xfer case??.....or would it be the truspeed calibrator??
The speedo cable appears to be tight... any ideas?
airlaird
I don't have any experience with the truespeed unit, but it could be either the sending unit on the transfer case or the speedometer itself. I had both go bad on two separate occasions. First the sending unit, then a year later the speedo went south. It should put out a code if it gets bad enough. Your OD light will begin to blink. The code will tell you which one it is.
Good luck.
:rolleyes:
OK, so if it is the sending unit...would that be the truspeed unit acting up in my case?? I presume the Truspeed unit overides the factory sending unit?
airlaird
