Speedo Cable Question
I just got a new one....no washers with it. So, I'm using the one felt washer and one metal washer on the t-case end that came with my old one. Metal washer against T-Case, then felt...then cable.
Sounds like I'm missing some washers....but that is how I did it anyway.
Thanks Herb. This is the pic that shows the 3 "washers". Similar to yours?
Yep, except that I only have the felt (or plastic in this pictures case) and the small metal washer. I used them both on the tranny side.
I think, with the three washers, you would put the small metal one inside the speedo gear housing first, then the plastic/felt one, then the bigger metal one on last. That is just a guess...and how I would do it if I had all three washers.
Good luck! Maybe someone else will have a definitive answer here...
Speaking of speedometer cables, I have a 79 transfer case with the electronic signal adaptor on it. I'd like to bypass it with a longer cable. The speedometer itself is a 71. The PO replaced the cable repeatedly, and they kept failing. Probably too short. Which cable do I need?
As long as the end that attaches to the speedometer head is the push-on style, opposed to the thread on style, you should be able to use a cable from a 1974 or early 1975 since they were a one-piece cable from the transfer case to the speedometer.
:beer:
