Speaker Wiring
Comox BC
Can anyone with an LJ78 Prado or other JDM LC help me out with speaker wire color codes? I'm trying to install a new Blaupunkt deck and have found you can't use an off the shelf Toyota harness adaptor it seems.:frown: Mine had a radio/cassette deck with a separate CD player. What I'd like to find out is the codes for the 14 pin plug harness hooked to the old radio/cassette.
If someone has already taken the time to figure these out I would really appreciate your input.
Thanks
I just finished re-wirring all four speakers. I used all new wire Because I discovered the deck wirring goes to a small amplifier mounted above the factory jack in the passenger rear quater, and then from there to all the speakers (mine had 5 speakers, I removed the 6" sub in the rear door, there's a fold down table there now), I swapped the deck and all four speakers first but removing the amp and adding new wire improved the sound the most for me.
