Sparkplug questions
Denver Colorado
Hey guys, I changed my sparkplugs today and these are what I pulled out... Do you think they look like I might have a lean condition? I changed the O2 sensors 1000 miles ago and they looked the same. Any opinions?
'97 Lexus LX450 w/ 150,000 miles
LXTX; the images are too small too far away, got to get up close like in chibo's pics.
From what I can see, they look very good; how many miles on these plugs?
Is that rust on the insulators? Can happen if water gets down in the spark plug cups.
My OEM Denso plugs with 100K on them looked just a shade lighter than chibo's, (both the dark and light colored areas) just not quite as much white-ish deposits.
I would say that I could have changed out my OEM Denso plugs before ~100,000 MILES (~165,000kms); it ran fine, but I did notice that my gas mileage went up a tad and the idle smoothed out a tad when I switched to Iridium plugs; the exhaust note even changed from a growl to a smoother note. I would say 100,000+ kms would be no problem for a set of stock Denso plugs in an otherwise well running Toyota Landcruiser engine (normally aspirated).
Do you guys actually run plugs 100K km's.
Either I'm changing plugs far too often, or you guys are actually waiting till the engines start to "frumble and burp" in stead of purring along.
:rolleyes:
I have no idea how long those plugs were in, but they aren't OEM. Come on, this isn't a 2 stroke bike. :flipoff2:
@Gray
I've been looking at those iridium plugs. They seem a tad costly compared to platinum ones.
But on the other hand, if your running them that long and the engine still performs. Why not.
@Chibbo
Well I'm used to 2-stroke Stihl saws and the like.
The first thing that comes out is the plug ;p
Force of habit here in the shop.
I've got this little vauxhall belmont or opel astra 1.4i which received a new head gasket and engine tune up a couple of weeks ago.
Before the plugs were oily and fouled. Now they're burning nice and lean.
So I'll just wait and see when it starts burping along.
Off course you can't compare a GM engine to a TOY one :flipoff2:
I put 100,000 miles on a set of regular stock ND (Denso) plugs; they ran in the vehicle from the 100,000 mile mark to 200,000 miles on the odometer. They looked relatively good when I took them out.
At 200,000 miles on the vehicle I put in the Denso Iridium IK16 0.4mm center electrode. They cost around $10 US each +/-. I think they were worth it.
I now have 243,000 miles on those plugs; it is running very well. They will probably last 100,000 miles, I expect, unless I decide to pull them out early and put in the 0.7mm Iridium plugs (thicker center electrode).
Whatever type plug you decide to use, any Denso plug is much better than Autolite, IMO/IME.
