spark plug gap
The early 1962-1964 manuals give the gap as .9mm (0.035 inch) for the F135s, which use a different (shorter) plug than later F engines (F145 and F155).
The 1966 FSM gives a range of 0.8-0.9 mm (.031 to .035 inch) on one page, and on another it says .036 inch. (Again, these would be F135 plugs).
The June 1971 FSM recommends 0.8-0.9 mm (.031- .035 in) as well. F145 and F155.
But the June 1972 FSM gives 0.7-0.8mm (0.28-0.31 inches). That would be for an F155 engine.
Obviously there's a range, and, like Poser Steve mentioned, 0.8mm or .031-.032 is in the middle and a good starting point for any of the F engines, with the earlier engines maybe liking a larger gap and the later ones tending smaller.
Remember too, it kinda depends on the brand of the plug you use: some will be colder or warmer than others. I try to stick with the Denso plugs from Toyota.
This adjustment can be fairly critical and if it is maladjusted the engine may run badly, or not at all. A narrow gap may give too small and weak a spark to effectively ignite the fuel-air mixture, while a gap which is too wide may be too wide for a spark to fire at all. Either way, a spark which only intermittently fails to ignite the fuel-air mixture may not be noticeable directly, but will show up as a reduction in the engine's power and fuel efficiency. As the plug ages and the metal of the tip erodes, the gap will tend to widen; therefore experienced mechanics often set the gap on a set of new plugs at the engine manufacturer's minimum recommended gap rather than in the center of the specified acceptable range, to ensure longer life between plug changes.
