spare winch tool needed
Los Angeles, CA
So along with the warn controller, the PO of my 80 appears to have kept the stock lug wrench and anything else associated with the jack (except the jack itself for some reason). Now I need to get my spare out and am a little stuck.
Are there any secret ninja tricks to lowering it? Do the items that come with a toyota pick up or something work? Does anyone have one laying around they want to sell cheap?
Thanks in advance,
Tyler
If you can get a socket drive -- about 3/8" maybe --that is roughly 2 feet long, it will reach through the hole into the mechanism? Might work, anyone know? I've always been lucky enough to have my kit.
The other trick is to loosen the three bolts that hold the spare tire mount assembly to the frame rails on each side. That takes the whole darn thing out, IIRC. Then you can deal with it off the truck.
That's a good idea, thanks!
Take it to a tire shop
Betcha they could remove it pretty quick if you slip them a $5 spot. They usually have all the tools necessary so that they don't need to dig around in the cars they are servicing. Once off you could play around with the winch mechanism to determine what will work the best in the future.
The tools from any toyota pickup will work at least all the toyotas I hav had all had the same one you could check local wrecking salvage yards I had a 90 4wd p/u a 1991 2wd p/u 1985 60 series and the current 97 80 all used very similar tools for lowering spare tire.
