Spare wheel carrier
Christchurch, New Zealand
Hi all,
quick question.......;)
My HDJ81 does not have a rear mounted spare wheel carrier :o
I want to fit the genuine one. Is there and mods that need to be done to my truck to make it fit. Is the standard body work up to take the weight?:frown:
Chears
From what I've read, the rear-most corner has to have extra strengthening--something US spec models don't have. I don't know if yours does or doesn't. You'll also need the lower rear gait with the appropriate indentations for the latching mechanism.
-Eddie
Dazlinsky,
I think the short answer is 'no - you can't fit a tire carrier on if it did not leave the factory with the considerable structure and hard points welded into the body for the factory mount without serious fab skills and body work.'
DougM
Dazlinsky,
DougM
There's an 80 near me that had the job done and now sports a spare 35" tire. It looks OEM, but it worries me. The reinforcement was in 2 peices and regardless that they sprayed anti-rust into the pillar, I have my doubts and will try to have another look a couple of years down the line. I believe that any welding work on sheet metal makes a new creche for rust and meticulous care only delays it. Besides, I'm also not too sure if a 2 peice reinforcement has sufficient strength and durability.
Kalawang
Thanks.
I thought it would be a big mod to fit one:o
I have my spare on the roof but it worries me that I have increased
my center of gravity:confused:
Just move the spare inside for serious wheeling trips if you're on very tippy terrain. Frankly I wouldn't worry much since you don't have a serious lift where added roof weight would be an serious issue. Not worth the time/effort to install a factory tire rack - I'd consider an aftermarket bumper with rack as a time saver that would not cost much more by the time you paid someone to do all that fabrication, body work and repaint the body. Might even be cheaper.
DougM
Someone likes MUD :bounce:...
Had a jeep CJ7 back in the day and the factory body mounted rear tire carrier with the larger than stock wheel/tire combo eventually started tearing away at the sheet metal :o from off road jouncing around. Go for the frame mounted unit aka Slee.
