Spare Tire Installation
Philly
Just picked up my 1994 fj80 and the tire was in the truck, not under it. This is my first time using a crank system like this. I have the tire back up but theres a hole that looks like a lug nut can fit through thats aligned with the rim, should there be one? Also, there was a hole in the carrier that acted as a guide that poked through a lugnut hole of the rim, is there some type of circlip for that?
Come again?
I just R/R the spare tire on my 1997. Yes, there is a tab that pokes vertically through one of the rim lug nut / stud holes from the center carrier. I would guess it would be for a lock or pin (I didn't have or use either).
Ah ok, so basically just put the tire on the ground, align the carrier and crank it till the spring is tense? I just wanted to make sure I wasn't missing any parts that could cause the thing to fall off while driving.
That’s it
