2mbb's tire carrier on the cheap (my version!):
You'll need one of the eye bolts you see in his set up, and a large U bolt.
1. Drill two holes in the metal under the window appropriately spaced for the two legs of the U bolt. Set the tire in there first and get an idea as to where you need to drill the holes....
2. Put the eye bolt on the U bolt and put into the holes you just drilled. Eye bolt hangs on the outside.... duh.
3. Fender washers on the inside of the U bolt (both sides would be good I guess).
4. Put the eye bolt through the lug nut hole and use a bolt and washer to tighten.
5. Done.
My 33x11.5 destination has been mounted this way for about two years. It's very solid, and very cheap. 2mbb's looks nicer, but I don't have metal fab tools.
5. Done.
