spare keys
Knee deep in hookers and gin
I have been told by a half a dozen lazy hardware store guys that the 80 key blank is a dealer deal. I found one just now that looked a little further and found that a TR-40 key is listed as an alternate for the LC. It has a different plastic head shape. Looks more like a Tercel key, but it works.
A student brought his dad's 55 chevy in today for the last day of school and proptly locked the only key in the car. Reminded me that I needed a spare zip-tied in a secret place on the Cruiser.
got 2 or 3 made at Walmart for $1.50 each. Work perfectly.
E
Are the Toyota keys different from the Lexus keys? I'm guessing you can't get these done for $1.50 a pop.
[quote author=hoser link=board=2;threadid=17746;start=msg171883#msg171883 date=1086798745]
[/quote]
yes they are diffrent AFAIK only a lexus dealer can cut those, I understand they are closer to $50, fortunatly my LX came with 3 keys and 2 fobs
my 80 LC keys are the usual type with "teeth" on the outside of the blade.
E
Bought mine for $ 23 at a local Lock Shop. Cutting is not a copy but rather a machine that reads the origional an then cuts the new one.
my 2 cents
[quote author=RavenTai link=board=2;threadid=17746;start=msg171886#msg171886 date=1086799050]
[/quote]
The service guy at the Lexus dealership told me that they outsource the key cutting, but wouldn't tell me where. I'll see if I can get the info out of him. When I bought mine, it was missing the 2nd master key. Only had 1 master and 1 valet key. I got them to cut a new master key for me. The valet key opens everything but the glove box and rear cargo area lock.
does the valet key look diffrent? wonder if one of mine is a valet?
Gents,
Looks like I'm your key guy. I the proprietor of http:www.fastkeys.com
The proper keyblank for an 80 series LC, 91-98, is a TR44(non-plastic head) or TR44-P(plastic head).
A TR40 will work. They're the same keyblanks, just different heads. These 2 keyblanks interchange with different Toyota models.
Unless you have a '98 - newer LC, you won't have to worry about the higher security keys.
According to my book, Lexus has always had the high security keys(sidewinder cut or snake cut). Usually, if you can get them for under $50, you're doing pretty well. You do have to have the special key machine to cut those.
Key cutting usually means, giving me your old/existing key and I trace it on to a new keyblank. If you want a factory cut key, you will need to go a locksmith with a key code, and have them cut you an new key. Hopefully, they do have a code machine w/the Toyota code cards.
A locksmith should also be able to take your existing LC key and read it, and be able to cut you a factory cut key.
A locksmith friend did that for me the other day, but I haven't had the chance to try it out yet.
Some car dealers can cut you a key from you vin#. Just depends on how new your vehicle is. Usually, you will need to show proof of ownership/registration.
I do stock most Toyota keyblanks, even the old, old ones.
Hope this helps a little bit. Let me know if you have any further "key" questions.
-Cesar
[quote author=RavenTai link=board=2;threadid=17746;start=msg172094#msg172094 date=1086815799]
[/quote]
The shape of the head of the valet key is different for the LX 450. On other vehicles have different ways of identifying the key.
Easiest way to test is to lock the glove box with one of your keys and try to unlock it with the others.
97fortieth4me, had an idea the other day, my key chain was way to heavy, has anyone ever considered making Titanium key blanks? Titanium is the only light weight metal I know of that would stand up to the abuse, I wound up breaking off my less often used keys into task specific sets and that cured my problem but still like the idea
Titanium is expensive and expensive again to machine but I think there may be a market on the 'net for something like if the price was right, we all know people spend money on more trivial things.
Not sure that a hardware store type key cutter could cut the blanks
Any other ideas on how to cut down Key weight? I don’t think that Aluminum even the best alloys would hold up
[quote author=NorCalDug link=board=2;threadid=17746;start=msg172159#msg172159 date=1086823712]
[/quote]
thanks all my keys look identical, I guess I do not have a valet key (don't need it)
Raventai,
I have cut a few "titanium" keys in the past that someone had brought over. I think they were either "Acura or Nissan" keys. They were a little bit tougher to cut, but I was able to cut them with no problem.
Like you mentioned, titanium is very expensive and expensive to machine. I don't think there's a high enough demand for titanium keyblanks at an affordable price.
Aluminum keyblanks were available in the past, and I still see them every once in a while, but they were too brittle of a material for keys, so they did without them.
I always tell my customers to keep the most original copy of their key in a safe place, or use it as a back-up. If you ever need it copied again, get it copied from the older/original one.
The strongest keyblanks that I have found, as far as vehicles goes, are the factory ones. They tend to have more steel in them. All or most aftermarket keyblanks are mostly brass w/ a little bit of the other metals to make them a little stronger. They normally come in either gold(brass) or nickel plated brass. If you have an aftermarket key that is nickel color, you can look at the cuts. You should be able to see the brass color within the cuts.
A good way to lighten-up you're key ring, if it's getting too heavy, is to separate your vehicle keys from your house/shop keys. You can use what they call a "pull-apart" key ring. They come in a 2-way pull-apart or a 3-way pull-apart.
A real titanium key would cost $3-800 just for the blank. Acura offers a "titanium" key ($100) but it is really made of Monel, a nickel alloy composed of about 70% Nickel and 30% Copper. This alloy is used in many marine applications and is highly resistant to saltwater corrosion (as in sweat.) Like 97fortieth4me said, it is somewhat difficult to machine.
Ouch, I knew it was expensive did I did not know it was that expensive, next time I make a titanium doubler I'll be nervous :eek:
