spacers
I see members talking about spacers for a lift. Where do I find them and how well do they work? Also how easy is the installation? I am putting 33s on my cruiser and want a little more clearance. I want to make sure they do not rub.
Man-A-Fre and Slee Offroad both sell coil spacers. Do a search for 'coil spacers' as there plenty of threads on the subject.
And for the record, many have fit 35's with stock suspension. 33's should be no biggie.
I could not get 33s in stock form to rub no matter what I did to it. Stock wheels as well.
Rubbing and fitting are two different issues.
I have minor rubbing of my 35's on about 3.5" of lift + 1" body lift. In order to eliminate the rubbing completely I'd need reduce my travel by about 2". The amount of rubbing will not harm anything, except I might need to spray some bedliner in the wheel wells every couple of years (mostly for aesthetics).
So my 35's fit, but they also rub.
35's will fit a stock lift, but rub quite bad--to the point where something should probably be done about it. 33's should fit a stock lift without any interference issues, but you will rub quite badly.
You can get any tire/lift combo to rub if you try hard enough. And you can get anything to not rub if you try hard enough...you just might end up with 0 flex. ;)
