Source for mini cv studs
Tacoma, WA
after a few failed attempts to find such an item locally, Im looking for studs for my parking brake drum that will fit the mini CV's. I wanna say the stock stuff is 8mm and the mini is 6mm but not sure. I know i have to redrill for the new pattern, and I would rather find the studs then do any welding.
mike
cardinal fang said:
Marlin Crawler for all things mini truck
didnt think about that. thanks bill!
John Smith said:
When I put a minitruck driveshaft on I drilled out the flange on the driveshaft and it fit over the factory parking brake studs just perfect. The pattern is correct you just need to increase the hole size.
I thought about that, thing is, my drum has a different pattern. and there does not appear to be that much room for increasing the size of on the mini cv.
thanks again, mike
