Source for banjo fittings???
Kansastitty
Other than the salvage yard? For the Monte calipers. The ones from Summit say for Teflon hose, is that a problem?
Did search and go through tech links, but not too specific. The bolt is metric like a 10 x 1.25, I have the copper washers that came with the loaded calipers.
Ed
Why don't you just run the Raybestos (38409??)hose that converts from metric stock lines to banjo fitting? The banjo ends on the hoses are huge though, I filed mine down a little and used the longest bolt they had.
Thanks. I'm using a GM master so no need to convert the rears to metric. I am running all new lines and didn't realize that the banjo fitting came as a part of the line itself. I was looking for a banjo fitting with no hose. Trying to make it more complicated that it oughta.
Story of my life...
Ed
the cadallac calipers with e-brake have the independent bango fitting (no hose attached), direct steel line to fitting
maybe this guy knows?
:D
A JOKE......at anyone's expense.
There are both the separate banjo fittings and the hoses with them built in, so I was STOOOOOPID. Can't help it.
Ed
Do a google surch for Earl's performance fittings........you'll find em. ;)
they are the same, that is the guy from Deliverence :D
haystax said:
Ha! He's probably looking for his banjo, maybe the dude in the photo stole it.
Ed, are you using the Corvette master? I'm considering that for my 4WDisc conversion, keeping a non-power master. I was going to go with the bigger IFS calipers (I've got mini knuckles) but concerned about the amount of fluid it would take to push them. Have you heard anything about that? I pulled a pile of brake hydraulic equations from the Birfield archive, but haven't been up to the task of grinding out the numbers . . . .
Yes, I'm going to use the '75 Corvette master for 4w discs non-boosted. I believe it has a 1" piston and may have to redrill the brake pedal for more travel, but I don't know that yet.
I'm also making a plate adapter that will space the master out just far enough to clear the rear outlet on the master from the firewall brace. Shouldn't be a problem for later years, but mine is a '66 and until I have to, I don't want to cut the brace.
If none of this shizzel works, I can go back to something else. Oh, and I'm going to install a proportioning valve...because everyone here and on POR says I'm STOOPID if I don't.
I'll keep the patterns from the adapter and maybe do a write up on it if it works,
Wish me luck, 'cause I need it.
Ed
"and whatever else I can sneak in the garage while no one's looking. "
I Love that!
