Soot in the Plenum
Florida
A while back there was a thread about controlling soot in the plenum. To control this, a catch can was employed between the PCV and the TB. I was wondering though, why would soot be coming from the PCV? It seems to me that the soot would come the EGR. My theory is that soot coming from the EGR builds up in the plenum because of oil coating the inside of the plenum as it blows in from the PCV. So, by using a catch can on the PCV, the amount of oil is reduced or eradicated all together, so the soot can travel unimpeded through the plenum into the cylinder. Am I right? So if controlling soot in the plenum is the objective, the only way to do that would be to use some kind of particulate trap in the EGR system. Or is the point of the whole exercise to eliminate soot build-up in the plenum, so that it won't restrict air flow? Am I missing something?
The actual soot comes from the EGR, you are correct there. The PCV is the problem as the oil vapor acts like glue and causes all the EGR stuff to gunk up, correct again. The idea is that EGR soot is not a problem as long as it just passes through, I just eliminated it all on my 3FE and I imagine things are pretty clean in my intake now.
Alkaline,
Cool. It always to feels good to get something right.:D I am the guy that put the stupid breather vent thingies on my PCV (like the ones on old Chevey's) so no more oil vapor is entering my plenum. But I wasn't sure if the soot would still be a problem. Thanks for the input.
Alkaline,
And you're the guy I copied by adding the breathers to mine also. I just ended up plugging off the egr lines, eventually I'll take it all off and put expansion plugs in the old egr ports.
