Sometimes hard to start when warm
Morristown, TN
My 1993 80 starts right up when it's cold but seems after I drive it and it warms up, it's hard to start. It starts but it has to turn over a dozen times before it fires. I just tuned it up with all new OEM parts but didn't change anything. No problem with the battery or starter, just doesn't want to fire up. If it sets for a few hours, I get in and it fires right up. My buddy things it's either a fuel filter or injector problem, just curious if anyone else has had this problem?
Thanks for any suggestions or advice...................10ga
i had a similar issue with a leaking fuel injector. After sitting for a short time i had difficulty starting. it would stumble when starting initially. if sitting for a while or overnight would start up fine. turned out to be a leaking fuel injector. after replacing i had no further issues.
Tredwards, how did you track that down?
Fuel pressure gauge question
Above is the thread i started when i had the issue.
This whole process drove me crazy. If i knew then what i did now i might do things differently. Basically i would put a fuel pressure gauge on the "out" side of the fuel filter and check your pressures. i believe i have pressure readings in the thread but i noticed that the pressure bled off more quickly with the leaking injector than with the new ones. Another option is if you have a bore-scope, you can pull the various spark plugs and look into the cylinders after shutting off the engine and see if you see one dripping. I ended up pulling all the injectors and took them to a local fuel injector tester and found one that leaked. Then i called Onur in a frenzy and ordered all new injectors so i could finally get this frustrating job over. In the end it all worked out, issue is resolved, and i have had no issues since. the hard starts immediately resolved after new injectors put in.
During the process i replaced fuel pump, fuel lines, and a large amount of the fuel system. In the end the fuel injector was likely the culprit all along.
Had the same problem on my 1991 with the 3fe. It was my fuel pressure regulator. It would allow to much pressure in the fuel line when warmed up and cut off. This in return damaged the check valve on my fuel pump. Long story short I changed the regulator ,fuel pump,fuel damper and fuel filter. All has been well after. Good luck.
Thanks guys, this give me a place to start. It always starts but I hate cranking on it to get her going. Everyone gives you that look like, is it going to start? Not to mention more wear and tear on the starter and battery. If I wind up getting new injectors, where's the best source or is there a place to send them off to be rebuilt?
