something is binding up
Boise ID
I dont know if i can explain this right so you guy can know but here it goes. When im moving forward everything is fine (stock drivetrain F three speed) when i push in the clutch i can hear the gears or something rubbing together and not wanting to turn. Then when i put it into revers and start backing up something gets binded up sounds like large clunking. dont know if this make sense. Checked the rear with and aussie in it and that is not it, it still functions properly. Then when i turn sharp i can here it along with the locker. I have a 5 inch lift with stock driveshafts and was wondering if it was that stripping out. I dont know. Hope this makes sense.
Adam
Have you tried holding the shifter in position? Or make sure you 2wd/4wd position is solid and not bouncing on the other?
When i am rolling in first and take it out of first into neutral i can feel it disengage i dont know if that is normal for a nonsynchroed first gear. Everything works fine went wheeling this weekend and just this stuff continued. IT shifted fine in and out of four wheel.
this might be a problem
