Some wiring issues
Australia
Can anyone tell me what this burnt out wiring used to rum. It's directly behind the dash. The red connection.
Also I recently noticed that the 2 sets of wires that come out of the transfer case have been cut off leaving 1m of wire. I am guessing they run the tacho and 4wd light indicator as they both don't work. Maybe that's connected to the burnt connection behind dash?
Many thanks
Hammo
Sent from my z6
It's a grounding junction for several accessories. Your headlights probably burned it up.
To prevent that from happening again in the future and causing a fire and burning your car to the ground, install a relay wiring harness for your headlights. ARB has a good one. Easy to install
More info can be found
HERE
The transfer case has a ground wire that normally attaches to it. See pic below. There is also one screw in spring loaded switch on the p side of the case that turns the 4WD light on & off. That's what the ground wire is for.
