Some trouble running
Put a brake master cylinder on my FJ40 today and im sure its not related but after taking it for a test drive it started running terrible. After sitting for a half hour or so it'll run good for about a quarter mile then will act like its gonna cut off and buck then you can idle it and pat the gas a couple times and it'll idle perfect. Then take off again and it runs rough gotta ride the clutch to get it to move. The longer you let it idle the farther it'll move. Like if you wait 2 or 3 minutes it'll maybe run 100 feet before bucking again. It just recently had a tune up. New filters plugs,wires, distributor cap, roter button. Practically everything thing before i bought it. Maybe not a coil though didnt check. Any help is greatly appreciated.
Yup the brake master. I checked and double checked all lines,all were good. I think it may be as simple as a weak pump. When i last ran it last night it stalled out so i just left it and this morning took the air filter off and pump the throttle linkage and couldnt get any gas to shoot into the carb. Then i started it and let it idle and cut it back off then i could get gas to shoot so which makes me believe it was running out of gas last night.
