I'd hate to see all talk of clunks fade into history....
I've been trying to troubleshoot some mean clunks I've been getting lately, and I've got a few questions for the clunk veterans out there.
Some of you may have read posts where I describe the (seemingly) excessive play I get with my Aussie Locker-ed rear diff--if not, here's the deal:
Since installing an Aussie Locker in my rear diff about a year ago, I've been getting good, solid clunks on and off throttle. I do realize that the nature of auto-lockers introduce significant backlash into the differential, but mine seems to be getting worse over time, and doesn't seem to match what other Aussie-running 80 owners are experiencing.
1. Lest weekend I pulled the rear 3rd and found everything looking beautiful. No wear whatsoever on the cross-shaft, no detectable play in the r&p, pinion flange or carrier, and the splines on the axles looked great. This seems odd to me--considering I measured 20 degrees(!) of play at the diff input flange with the driveshaft disconnected. There was a little slop between the axle splines and the Aussie "side gear" splines, but I can't see how that could create the 20 degrees of slop at the input when installed on the truck?
2. Running in front wheel drive (with the rear driveshaft out and the center diff locked), everything seems tight and smooth.
3. I haven't specifically checked yet (still have the rear driveshaft out), but I don't think I'm getting near the clunks with the center diff locked, under normal (running both driveshafts) conditions.
4. I've got play at the t-case output, a little bit at the driveshaft slip joint splines, and a little bit everywhere up front. My drive flanges up front are tight.
5. I've got the classic driveshaft slip joint spline clunk. I have to grease mine every few months to keep it at bay.
6. I'm running 80w140 in the rear diff, per Aussie recommendation.
Other than soliciting general comments, I've got these specific questions:
1. What is the final word on the McNamara gear solution that applies to the transmission output on FJ62s? Does that apply to A440 FZJ80s?
2. How could I tell if my transfer case might need some attention?
3. Would buying a new driveshaft(s), with new and tight slip joint splines make any noticeable impact?
4. Could running the heavier gear oil in the rear diff affect where and how my slop is taken up?
Thanks for your time.
Ryan
Ryan
