- Joined
- Dec 2, 2004
- Threads
- 126
- Messages
- 821
I'll bet they all do it, but my crancase breather tube, which simply vents downward the ground from the engine, drips small amounts of oil.
In my effort to make her oil-tight, I'm thinking of ways to prevent this. Would I be causing a venting problem if I attach a foot of rubber hose, then curl it back up and zip-strap it to the breather pipe itself like a "p-trap"? What about some sort of catch can like the racers use?
I just added a longer section of hose and have it dumped past the frame. The only downside to this is when slow going you might smell this stuff as it is blown up your way. You also could add a piece of hose long enough to run to the back of your rig so it vents behind you and then you might not smell it.
