on the solenoid for the f engine is a white wire, any idea where that goes, my old starter had it going nowhere, also there is a small post with two nuts, any idea if anything goes there?
The white wire is probably for the bypass around the ballast resistor on the coil. I can't remember what color that wire is, but it should have a spade plug (socket side) with a plastic cover around it on the nd.
This wire hooks to the + side of the coil to bypass the ballast resistor when you are cranking the truck. It puts the full 12 volts on the coil to give more of a "kick" when starting. It makes a big difference if it isn't hooked up.
To be sure this is it, you can put a volt meter across this and a good ground and have someone crank over the starter. You should see 12 volts when the starter is engaged.
