soft top
hey guys
got another question for you guys.just a quick question, how easy would it be to fit a soft top im thinking something along the lines of this
https://forum.ih8mud.com/merchandise-storefront/326260-canvas-soft-tops.html
to this car,
Also where is a good place to get the bars to support it? and how easy are they to fit? (im in Australia)
thanks again guys :)
That the best canvas that you can put on a 40, OEM style, there's a member that sells a replica of the OEM bows or check ebay, then you have to buy the canvas separate or if you are lucky try to find the bows on a junk yard down there in Australia..
OEM Bows
Here are the sources for OEM reproduction bows:
Toyota Landcruiser FJ40 OEM style Soft Top Bows | eBay
These are the full set including windshield channel. I don't know about shipping to OZ.
Same company, but just the hard-to-make pieces. You would need someone to bend-up the bow pieces, but measurements are included with this kit.
Welcome To PakTops.com
This is the US distributor for Pakistani-made replica bow sets and OEM-style tops. The owner of Paktops.com is on IH8MUD and his handle is SouthBostonFJ. Here is a link to one of his threads in the Merchandise section:
https://forum.ih8mud.com/merchandise-storefront/356988-paki-soft-tops-bows-boston.html
Lomusass, here on IH8MUD, makes many replicated parts, including bows. Here is a link to one of his threads:
https://forum.ih8mud.com/merchandise-storefront/64377-new-steel-tubs-fj40.html
Lastly, the OEM canvas top you linked by OCDBeetle is the hottest top going...but be prepared to wait for one. You might want to contact woytovich directly to inquire as to shipping to OZ and wait for a new top.
I cannot post more pictures because I'm not important yet.
You can search my couple of posts and look at my rig. All I used was a simple rear roll gage and a tube bent to fit the holes in the body where the pegs for the hard top drop in.That keeps it in line with the windshield frame. It works just fine with the original hard doors. I built half doors and am planning my "drop in" side windows to do this week.
They'll bhave three drop in pegs on a 3/4 inch stainless box tube frame with a zip in window panel.
On the top itself, I spent $160 in material and hardware, cut and pinned it myself and the guy sewed it and seam sealed it for $20 ( 4 hours).
Figure a couple hundred labor in the states and you are way ahead the "second" BestTop.
The fabric I used was marine grade 1000 denier canvas, waterproofed at the factory in Columbia. I'm sure DuPont has something to work for your application. Basically it's kikkazz boat top and tent fabric.
It's about $26 a yard here, cheaper in the states, I'd imagine.
OCDBeetle is currently very backed up in getting tops out, so be prepared to wait (my guess is he won't be caught up with current orders until next year). Also consider that the factory reproduction bows may interfere with your existing roll cage. If you do get bows, they are very expensive if you plan on getting new reproduction parts. You'll also need to make sure that you can properly mount the factory bows and tie down the soft top. For example your current aftermarket tailgate does not have the factory tie down footman loops, and neither do the corners of your body. Those will need to be drilled out, if you want a true authentic look, or you can go with twist ties.
Check ebay. I recently saw a nice clean set of factory bows go for $58. I would have bought them but I couldn't get down to Victoria at the time with the 40 being repaired.
I bought my factory soft top off ebay for $150-odd plus about $60 for the courier. Once again, from Victoria.
There's not many in Aus, but people seem to want to get rid of them.
