Soft top question
Phoenix, Arizona
while installing our frame on the 40 today these trim pieces are loose and can be removed, do you fit the top behind them then put them back on and install the 3 bolts inside the frame to secure them, in other
words are these a trim pieces that holds the canvas in the top of the door frame?
Thx, R
The two door header pieces have to be screwed together. The soft top flange has to slide into that groove on the door header that you show spanning the door opening, after the top is attached to the windshield rail.
Somebody, probably JohnnyC, recently posted the installation instructions and I saved a copy. I just managed to find them. They're not particularly clear, but they might be helpful.
