Soft door problem - Help
Hi All,
I tried to put on the Bestop half doors that I bought with the cruiser. When I mounted the striker and the door the latch would not connect with the striker. In fact there is about a 1/4" gap. I thought I was using the wrong striker so I ordered a set from Bestop for a 1970 FJ40. When I got the new striker they were identical to the ones I had and so the problem persists. At this point I wanted to make a spacer to get the striker so the latch would hit it. This is the paddle style door. Both sides have the same issue.
Am I missing a part somewhere? Anyone else have this problem?
Thanks in advance,
Roman
Door fit
On my 79 those doors fit fine, nice and tight. When I put them on my 74 I have the same issue as you do. Must not be as much adjustment on the older Land Cruisers. I tried with the orignal door strikes with the same results. Wonder if the original 79 door strikes would work on the 74? Have to try that this evening. Either that or fab up something. The rattling is annoying, drowns out all the crusier noise!!;p
thanks Shark, the doors fit perfect it's just the latch is too far away from the striker. i searched the forum but couldn't find anything on this.
i loosened the bolts on the handle mechanism to try to adjust it but there is none to be had.
Stick some flat washers behind the striker until it's the right distance and secures right.
ok, trivia question. What size are the screws that secure the striker to the sliding brackets inside the door frame on a 1970 FJ40? I picked up an assortment of screws and bolts and they're either too small or too big.
I spent less time fixing more complex issues on the Cruiser ... LOL:bang:
I got some 1/4" ABS from my shop, cut to shape and drilled. The plate in the door frame is adjustable so I just drilled a hole with no slotting. It works perfectly but now I have a bolt issue since I can't find it.
