Soft Brakes
Sparks, NV
O.K., brakes are soft when you push on the pedal, I've replaced all 4 rotors & new OEM Pads all around, bled the brakes...twice, now while searching the forum I find that their is a "Load Sensing Proportioning Valve" that should be bled...Where is the darn thing? Oh yeah, 97 FJ80
Above the rear axel on the drivers side, follow the hard line to it. Not quite at the wheel well, maybe easier to see it sitting on ur butt behind the axel if you don't have the spare tire hanging down.
-A
Scratch that or add to it, above the axel right in front of the rear drivers spring upper bucket. See pic taken from rear of axel... Just bled mine yesterday, all 4 corners and LSV with 2 empty calipers what a PITA.
Ammo
What kind of shape are your brake lines? Original OEM rubber. They could be getting soft. Consider new ones or stainless braided lines. Noticable difference. Those oem lines are getting old.
Bleed, bleed and bleed some more.
X2 I've blead mine without bleading the lpv and have nice hard brakes. Are yor bleading in the order that the manual calls out?
I really have not considered that the calipers may be "Under-performing" and have been thinking either the master cylinder or booster may be the cause, also remember reading something regarding ABS needing to be activated when bleeding...not sure what the next step will be?
And then the next step would be to search. There are literally dozens upon dozens of threads dealing with brakes.
Lots of things it could be:
Master Cylinder
Brake Booster
Misadjusted brake pedal
Soft lines failing
Hard lines tweaked or letting air in
Brake bleeders (on calipers or LSPV) letting air in
Air in the ABS actuator
If it's the last one, you'll need to take it to the dealer and have them activate the ABS system while bleeding the brakes. Should cost you around $100 to do.
I just replaced my calipers last week, what a world of difference that made. One piston in both front calipers had seized.
That was exactly my expereience! After replacing all seven lex brake lines, new pads, and bleeding forever, my '96 still stopped like a third-world school bus. A Forum member pointed out that my uneven pad wear was probably because of stuck or sticking caliper pistons, so I replaced the calipers (NAPA - Toyota remans)... now the sucker stops! :clap:
pull the dust boot off the LSPV and check to make sure there is no break fluid in it, if the valve starts to fail it can leak into the boot without showing any sort of leak on the outside.
you would be surprised how much fluid that boot can hold:bang:
Did bleed the LSV this morning with no change, thinking more about the calipers as they are the original ones, I've rebuilt the rears not long ago and was wondering should I rebuild the fronts or just go with replacements...maybe call CDan?
I think the general consensus on the board is that 80 brakes are a SOB to bleed and get all air out properly. I recently replaced all soft lines, calipers, pads and rotors. Was super careful about trying to plug hardlines and not loose all fluid, but even after 4 bleeding's, using both 2 person method or motive or both, there is still air "somewhere" in the system, and I've got no pedal.
I guess just keep at it with the bleeding.
