Hello Everyone, I am trying to following #105 on this Master Cylinder Rebuild - DIY. After (e) loosen the push rod lock nut (right turn couple round), my brake is back to normal without soft brake and not down to the floor when pressed; however, how do I (f) Adjust the pedal height by turning the pedal push rod since it is already at the correct height? and (g) Tighten the push rod lock nut (Torque: 19ft-lbf)? The Push Rod nut and pedal push rod are around 1/2 inch apart. Any help would be appreciated
