SOF2RH Slee Rear Coil Springs
Los Lunas, NM USA
I recently purchased a used set of SOF2RH springs. There is no tags on the springs to identify which spring goes on which side of the vehicle, besides the actually height of the spring. On Slee's website they state free weight Driver Side – 455mm, Passenger Side – 465mm. I always assumed the longer spring would be on the driver side due to fuel tank on that side. I want to confirm if this is correct?
I have not run the Slee springs - but I agree with your assumptions as other brands I have run recommended the taller Spring on drivers side.
I emailed Slee I hope they get back with me soon.
On IFS 100 series, the taller rear coil usually goes on the US driver's side.
Slee off-road responded stating the longer spring goes go on the fuel tank side.
