Socket sizes??
Milwaukee, WI and Louisville, KY
What size socket do I need for the top of the birfield knuckle, (Where you insert more moly greese) and for the drain and fill plug for the differential?
The PO was supposed to be getting me a FSM but that fell through. Anyone know where I can pick one up cheap?
JP
The plug on top the the knuckle is a square plug so you will need a spanner or just use and adjustable spanner.
I believe the diff plugs are 24mm. If you play in the rocks it is a good idea to replace them with 10mm hex plugs.
-B-
The plug on top of the knuckle is 13mm square. You can also use a 14mm hex socket.
Beowulf is correct on the 24mm diff plugs, but I find 15/16 fits better.
One thing I've noticed working on my LC is that a lot of bolt heads seem to be even sized numbers 10, 12, 14 (except rear brake caliper bolts at 17mm). I'm sure there are other odd sized hex head bolts, but has anyone noticed if the majority of bolt heads are even numbered or is it just in my head?
breathed
