SOA-FJ60 axles
Cruiserdrew
On the way there
Sacramento, CA
A question for those of you who have done a SOA and used FJ60 axles. I am comtemplating this, but do not want to outboard the springs. Can FJ60 axles still be used? It looks like the perches need to hug the differential a bit, but will the u bolts still fit? If you've done it, I would really appreciate some pictures.
Andy, I’m on the Wednesday run with you, so you ca see it in person. Myself and one other 40 run fj60 axles front and rear. The front axle is not easy to put in a 40. You have to outboard the springs just a little. I moved them 3/8 on each side. Trying to keep the axle centered is the hard part. The spring perch on the diff side ends up high on the diff making the ubolt a tight fit.
It is so much more work to get them under a 40 and not outboard. You have to notch the diff, notch the third, do some retarded stuff with the inner u-bolt. I like the added stability the out boarded springs give me, and my suspension is very well balanced front to rear.
Thanks for the responses. So then I guess the next question is, how hard is it to outboard the springs. I have limited fab skills/equiptment.
You are going to be needing fab skillz/equipment either way if you are doing a SOA. Outboarding is just another step in the process. It isn't much work, just a little bit of measuring.
Everything I have built has been with 5 major tools: Angle grinder, drill, welder, chop saw, tube bender.
