SOA fj40 f&r axle housings
CA
These are out of a FJ40. The front is professionally cut & turned, and was running mini knuckles and brakes. I have the steering arms that bolt to the mini truck knuckles and fit Cruiser tie rod ends. The passenger side arm is the double arm for cross over steering. The driver side arm also fits the Cruiser tie rod ends.
The rear is setup with the anti wrap perch's and shock mounts also has disc brake brackets for it. I also have 1 third member no carrier, and both rear shafts. some front inner shafts also.
Located in nor cal
$300.00/obo
David cel 209-256-2395
Interested would you ship to AZ? Where at in CA?
