SOA And Inverted Shackles
Western Slope, CO
Just finished the spring over on the rear axle, at the same time I flipped my rear springs to push the wheels out some.
I now have an issue with the rear spring hangers inverting, I tried pulling them back down. Loosened them, tightened them some, nothing seems to be helping. Also I think these are rough county 2.5" lift springs with one leaf removed, I'm looking for some FJ55 springs to put on the rear.
I can also tell you that the anti-inversion shackles(installed by po) are doing nothing for the situation.:mad:
Been searching on this, have other people gone with longer springs to correct this, cause the short side of the spring looks like it's just not long enough, or could I just go with longer shackles and be done with it??:confused:
best bet is to get longer shackles...
From there if you do FJ55 springs and relocate the shackle hanger to get a 45* angle at rest you will be good.
looks like I would have to move the hanger towards the axle to get a 45* on it. Does that sound right?
So like 2.5" or 3" longer than stock shackles?
You can move the solid hanger...or install longer springs....
Longer springs would be best...
Reversing your springs will not cause problems with your shackles. You've got something esle going on.
Mark...
