Soa 40 axles. Built
Status
Not open for further replies.
Elko, Nv
these axles are nice. set up for spring over axle. they will lift your 40 into the air! run 35's or 37's no problem. front axle is a 1976 model with disc brakes. also has the modern, bigger knuckes and new trail gear steering arms, set up for high steer. 4.11 gears in front and rear. NO POSI. the front axle was professionally cut and turned by proffits cruisers, and set up for leaf spring flips. the rear axle has all new brakes too and has the dual slave cylander set up. even comes with the shocks i used. these axles were built the rubicon and have less than 100 miles on them since the build. tranny broke in the middle of rubicon and i dont need these axles anymore. comes with rear leaf springs. $2000. call jeff @775-287-4529 thanks for looking:cheers:
Stock axle shafts & birfields? Stock gearing & open diffs?
the axles have the stock shafts and gears, which are 4:10s. the birfields and knuckles are the bigger modern version off toyota pickups. no arb's. has a high steer kit from marlin, i believe. this is a really nice setup.
Status
