The reason it sucks is that the 80 was available with factory selectable front and rear lockers, and they are there if you need them. Which you clearly don't at this point.
Now, I will say that the 80 needs lockers a lot more than lighter rigs in my opinion and experience. The lockers make up tremendously for its weight and other factors, and I find I am dual locked in a lot of places where I wheeled with just a rear limited slip in my XJ.
That's not a knock, it's a simple fact (or at least my simple opinion) that the 80 was designed around those lockers when intended for hardcore use. It is difficult to design a quad coil suspension on a vehicle this top heavy without turning into a slinky with a bunch of negative characteristics.
The front suspension is therefore not at all flexy, and that is often viewed here as a negative, but what it does provide is exceptional balance for a crawler this big, tall, and heavy. The front locker is the complement to the suspension in this design - it is not merely an add-on.
In other words, I think the 80's suspension design is quite optimal for dual purpose usage with pretty serious rock crawling in the mix, but only with the lockers. Without lockers I probably want a more stable rear and substantially increased front flex to keep that front end planted on climbs. Actually, without lockers I want a different vehicle - I'd take a 100 without lockers over an 80 without them any and every day of the week.
These things mean nothing to an urban warrior, and getting caught up in keeping up with the Jonses means the next thing you are missing is a big heavy ARB bumper that is going to save your life as you mow down pedestrians and deer and other vehicles, and on and on it goes (or maybe your city has a big problem with an exploding Kangaroo population?
None of this is to say that you can't wheel very capably without them and get magnificently stuck with them - I simply think the contrast of locked vs. unlocked in an 80 is quite a bit greater than other rigs I have wheeled, and there are very good reasons for this (weight, COG, and suspension design) that suggest the extremely rare factory dual locker setup was more than a marketing ploy.
