My Planned Buildup
Hello, I have not posted in some time, but still been lurking.
Well hopefully I will get started on my build soon, I have a 78 FJ40.
Here is my plan for this one, I would like to hear some opinions on this build.
Currently it already has, the 350 conversion, but I would like diesel, so I am planning a Cummins 6AT, or the NPR Isuzu engine, still doing research.
I plan on keeping the H42, and adding a Orion, that will put me at about 60:1 ratio, for the type of wheeling this will see, that should be plenty.
For the diffs planning on ARB's F&R, and new 4.11's so I have the fine spline. I might start out with Aussie's.
I plan on complete 30 spline Longfields up front, Poly Performance in the rear.
Then I plan on a 2-3" lift with 55 rear or 60 rear springs all the way around, still doing some measuring. BTW does anybody know just how much offset there is on a 60 rear spring, have trouble finding that.
For tires, I am planning on 34x9.50 tsl's on stock cruiser rims with hub caps.
It already has the chevy power steering box, so I will go with some sort of high steer system.
Then I am going to add the MAF 28 gallon long range tank, under the seats. With all the racks outback and on top.
Of course a 8274 out front, slighty modified with XP 6hp motor and solinoid pack.
Of course some sort of really nice cage.
And ton more small things, but over all that is the main build. BUT first I have to find and replace the 3/4 tub.
But I think that it will be a strong, reliable rig that will handle most Pacific NorthWest trails.
So what would be your thoughts, if you change anything I what to know why.
