I'm planning on installing a Safari snorkle and am assembling the right parts...
One of the previous owners pulled out the airbox and mounted a 12" round filter directly to the top of the carb. I don't have the airbox. I was thinking of grabbing an airbox from the junkyard (one that had matching exit hole diameter at the right angle to hit the carb) and bolting/bracing that in place. It I can't find the right diameter/setup, I'll probably put in an adapter or block off the hole and cut a new one in the aitbox and run a hose from the box to the carb mouth. The one thing I am concerned about is rainwater/dampness collecting in the air box. Since I don't have one to look at and the SOR pics aren's clear on this detail, is there some sort of 1-way valve or other drainage method for collected water to exit before being fed to the carb?
And while I say I'm looking at Safari, I'll admit I've also been surveying the Heep parts dealers for options and want to be sure I thoroughly understand the functions before I go for something not explicitly endorsed for FJ40 use...
Also, if anyone wants to sell me an FJ40 airbox cheap, that would be much appreciated also. Already checked Cruiserparts.net
THanks all,
John
THanks all,
John
