Snorkel related question
Christchurch, New Zealand
Hey all:cool:
On the base of the airfilter housing there is a drain (a can with a flap inside). Has anyone blanked there one off. Im just concerned that in deep water, the airfilter will start filling up with water and we all know what happens if that happens:eek::eek::eek::eek:
If the water level Under your hood reaches the catch can, it's too late. You've probably already shorted out other crucial ignition components.
The hood works like and unbrella if you will, during water crossings. The water level under the hood, with proper forward progress, is lower than the outside water level.
I agree with Wfd. I would add that you can drape a tarp in front of grill to reduce the flow of water in the engine compartment. I have use this method several times without overheating issues.:cheers:
Obvisouly, you don't want to stop in deep water crossings - steady, slow and after your diffs have cooled off. Nothing like the rear rising a bit and floating in a deep water crossings, of course 38s help that!:)
