- Joined
- Aug 26, 2008
- Threads
- 2
- Messages
- 12
2004 LX470
Getting strong fuel/gas vapor smell when parked.
I sealed to test, but would like to confirm this is a part failure and not a design feature.
Thanks in Advance!
Video here:
Thanks for the update - so it was not the pipe at all? Do you have any photos of the seams you are referring to? Any particular corner or edge of the tank to look at? When you smoke tested again, could you see the smoke coming from the seams? (assuming you had less than half a tank filled). Lastly, were you receiving the EVAP error codes?My solution....
Seams on fuel tank were curled up when installed. Trapped road salt and dirt, bad corrosion. Replaced tank with good used genuine LX470 tank. All good.
No problem at all @whereditgo - thanks for all these photos, very helpful reference for examining my own fuel tank.Sorry for delay...
Don't think it was the fill pipe. See attached photos of removed tank (signs of fuel seepage).. No EVAP codes.
Worked from both top/inside under second row seat, was familiar with this as I recently replaced a failed fuel pump (genuine/dealer part). Siphoned/drained fuel as tank was mosrly full unfortunately. Under to disconnect hoses and tank straps and lower/replace tank. Found a good used tank from same year LX.
Still getting faint smell of fuel after replacement, but not nearly as bad. Will need further diagnostics.
