Smoke on Startup
Unless there is some secret trick for replacing the valve seals that I don't know about, it requires removal of the head. NOT an easy fix. My assumption would be that if your engine is worn enough for valve seals to be bad, you need a valve grind too (Mine did), and the HG goes without saying. It's a matter of wht you can live with. If mine was a daily driver that never went more than 10 miles from home, it would still be untouched.
