smog system mess
central virginia
I am new here, i bought a 1983 fj60 last week and am going through the basic replacement of fluids, seals, bearings, gaskets and have noticed that all of the smog equipment is disconnected. the pump is still causing a vacum and exhausting but all the hoses are disconnected. The egr and all other emission components are present but none of them are connected. I want to rip all of it out to make way for space but am cautious. the engine seems to run fine no shutters or stumbles and good power for 193,000K and 33 inch tires. Any suggestions. Thanks
2 suggestions:
Get the factory emissions manual. I think it is about $12.
Do search for the desmog thread. Removing the smog equipment is not as easy as just ripping stuff out. The previous owner probably didn't do it right. Find the desmog threads and follow that advice.
And welcome to the forum.
thanks. I found the tech thread on smog removal and the link to the manual pdfs. the whole process seems ominous from the posts in the smog removal area, but i have no intention on putting it back. I live in virginia and there are no smog checks around here.
Thanks again
i looked at the pdf's and discovered that there is a bunch of stuff missing. the high altitude compensation valve is completely disconnected and most of the ports are missing. there arn't any mounatins above 3900 feet around here do i need to be concerned with it? thanks
