Smashed Exhaust
Washington, MO
Besides not driving over big rocks in the woods, what cost effective solutions have you seen to fix this design on the 96 (97?) L.C.'s
I can switch to a shorter aftermarket cat, and re-route it over the top of the frame like on the 93-94's. (My cats are in good condition yet)
Can I eliminate one of the two cats, and not throw codes.
I know there's been other threads on here about rerouting the exhaust over the frame rail--you may have to search around to find them. It has been done before. I haven't had to deal with this yet on mine.
On the cat issue, my understanding from reading other threads is the two OEM cats consist of one two-way and one one-way cat. The two of them should be able to be replaced with a single three-way cat without issues as long as the O2 sensors are reinstalled correctly upstream and downstream of the cat. Quite a few other members on here have done that with no issues that I have read about.
Hope this helps but more and better info will be found through the Search function.
Good luck!
Perhaps an easier solution woud be to fab a cheap exhaust 'slider' that you just weld to the frame right there. A simple piece of 3" wide 1/4 plate with 4 bends would make a box over that pipe.
I scanned over all of the 250 exhaust posts that came up in the search and couldn't find one that addressed this issue. I'm not exactly sure what search criteria I would use, besides exhaust. But I think I gave it a valant effort.
I have read about heat issues on the passenger side floor on the 93-94 when the pipe crosses over the top of the frame rail. I've seen this configuration on the trail, and there were no complaints from the owner.
I thought about the exhaust type slider, I actually have 5/16 bar stock, 3.5" wide bent and ready to weld . However, since I procrastinated, now I need to replace some parts, rather that fix the obvious problem to begin with.
Option 1:
I guess the best long term solution is to replace the two cats with one, cross it over the top of the frame, put some extra heat shield under the body, wrap the pipe and call it fixed. I guess my original cats could go at any time, or they could last another few years. I would also modify the cat/slider bracket and run it straight across to the frame rail bracket, rather that having the cat dip. This option is more expensive, but it would make my undercarriage "slicker".
Option 2: Replace the smashed section of pipe, and put the exhaust slider on.
Option 3: Run it until it breaks, or blows a gasket out somewhere upstream. However, it is my DD.
Option 4:
If you're going to replace that section of pipe ANYWAY- my suggestion would be to just route it over the frame since you're going to be cutting.
This might be more than you're looking to do, but now might be a good time to replace the entire 'cat-back' portion of your exhaust. Eliminate both cats and replace with a single hi-flow unit, use 2.5" pipe and a better flowing muffler.
I believe Clownmidget, Mabrodis, White Shark, Reffug, and not sure who else has exhaust over the frame rail....
Turbocruiser at one point was building an exhaust skid, not sure what his final layout is now.
And Firedog has over the frame rail exhaust in this thread:
https://forum.ih8mud.com/80-series-tech/122613-what-cat-should-i-use.html
2.5" pipe, I believe...
Obviously the '93-'94 did this without a body lift. Does anyone have a picture of this point from a '93-94 so we can see what the pipe section looks like and what kind of shielding it uses?
If you look under your truck, there is a recessed area above the frame about mid section of the 2 cats. That is where the pipe was previously routed. I believe there was a curved aluminium heat shield that conforms to this area also.
Hmm... I wonder what it would take to retro-fit a '93-/94 exhaust onto a '96 truck. What else is different?
Looking at the Bosal site, it looks like the '93-'94 only had one O2 sensor and the cats are pre-Y pipe. Is it the Y pipe itself that goes over the frame rail then?
Here is mine with an aftermarket cat. BTW, the '93 and '94 have an O2 sensor in each down pipe (before the cat) none after
attachment.php
Mine looks exactly like yours. Your muffler is in way better shape than mine though.
I've been thinking about fixing this problem as well. Going over the top was my original thought, but once you look at the space under there, it looks like it would be pretty tough to do.
If you do go over the frame, have the exhaust shop flatten the pipe a little where it goes over. With the pipe flattened into an oval there is plenty of air space for heat to dissipate.
I'm taking it to the muffler shop this morning at 8am.
They only stock the Magnaflow cats. The owner didn't think that they would be louder. I'll try to get that in writing. Cost will be an issue, but I guess if I decide to take off a non-code throwing set of cats, I'll just post them here. Surely someone out there has a set that is bad. I'll also call the local j-yard to see what's avai.
I'll see what they come up with.
Don't listen to me when I say "Hey, try to drive over that rock." :whoops:
For someone above who asked....here's a few pics of the 93-94 setup. The first is post cats, outside of frame. The second is inside the frame where the exhaust comes back down.
This guy fabbed up a mini exhaust slider --> https://forum.ih8mud.com/showthread.php?t=62089&highlight=exhaust+protection
Now only if someone could fab these up, heck, I'd buy one.
After talking to the shop this morning they said it would be better heat wise to leave things like they are, fix the pipe, and build a exhaust slider.
Therefore, I'll be taking the pieces I already have and doing a similar setup. Thanks for the link. That's exactly what I was looking for.
Since I'll have the welder and chop saw out, I'll fab up a 1/2 dozen or so extra. I'm sure someone out there would like to purchase one for a reasonable fee.
