i am currently running a 3" pulley and my boost guage says 8 PSI at the max.
i am having some minor problems with my intercooler at the moment, but i can tell you that if you are thinkin of the 3" pulley, you should consider an intercooler.
i am currently running NGK iridium plugs which also helped out.
my setup is a bit different than the TRD, but the compressor is the same eaton M90(as stated by others)
i have been doing some research on turbo boost controllers. there are mechanical adjustable controllers that you could put inline between the housing and bypass valve to control boost.
