SM465 Updates
Longview, Texas
I understand the snap ring / spacer between 3rd and 4th gear on counter shaft is a highly recommended update ($6.00 for spacer).
What about the 3rd and 4th gear syncro assembly (also called 3rd 4th slider gear ??) I have also seen on other web sites this is a recommeded update to also help prevent 3rd gear popping out. This is about a $100 update.
Has anyone done this syncro assembly with their 465? Should just replace the snap rings with spacer and call it good?
Thanks.
100.00us?
You are in there....
I would do it now so that you are not wishing that you would have later...
In the grand scheme of things, a hundred dollars is cheap inssurance.....
:beer:
Yea, tranny is on the bench, top cover and side plates off. Can see the snap rings on counter shaft, will plan to pull it out and replace with spacer.
I was just looking at Novaks site, and they show nice shematic. They sell the slider gear and syncro ring for about $30. Not sure exactly what I was quoted from other folks. It's was 3rd 4th slider gear update kit. For $100, got to be more than what I was looking on Novak's site. I'll do some more research and let everyone know what I find. I'll take some pics as I go for a later post.
