SM465 to 3spd T-Case
Whitinsville, MA
I have a quick question about swapping a SM465 to a 3 speed T-Case. I haven't purchased an adapter yet but I wanted to use the cool cruisers adapter. I know that you need to get a 10 spline output shaft on the tranny and I know of a guy that is selling one. He told me that it was a rare SM465 with an NP203. He mentioned that it is more common to see the SM465 with the NP205. Does anyone know if the bolt patern will be different with the NP203 and hence cause trouble using the Classic cruiser type of adapter? Just need to know otherwise I will not purchase this tranny.
Thanks for any information you guys could provide.
JRS
between a sm465 and a np205, there is an adapter that connects the two.
i'm not 100% sure, but i would imagine that the sm465's have one bolt pattern.
it's the adapter that prolly has the different bolt pattern for the t-cases.
anyone really know?
mace ;)
there is only one bolt pattern for the SM465....the one I used originally had the 203 behind it...
should be a good doner ;)
Thanks for the info guys. I will probably end up picking it up. The guy said that it came out of a running truck. Is there anything that I should look out for. Also what about price. He is asking $200 and that will include the bellhousing, sm465 and 203 Tcase. How can I tell that its actually a 465 vs say a 420 or another tranny? I just don't want to get stuck with something that I cannot use.
Well,
Very few 420's had an attached tcase...most were divorced..
Shift pattern will have reverse away from you and down.....
Look at the MANY PICTURES that are in the threads/tech links, etc out here on this very subject, and compare...hit Treeroot's Orion/465 install write up...there are great pics there.
Good luck!
-Steve
bustanutley said:
If it comes with the adapter between the 465 and 203 that is the rare piece, you could easily turn around and sell it for $100.
Thanks Poser the info should prove to be helpfull.
Bustanutley I wasn't aware that it was really rare. Just becasue the seller said so. I believe that it has the adapter because it advertised it as a SM465 with rare NP 203.
JRS
Sorry to get off topic but I’m trying to piece together the same set up.
I’m not familiar with the Cool Cruisers adapter that you are using. Is there a link for this?
Thanks,
JC
Thanks,
JC
JC the link to Classic Cruisers is http://www.classiccruisers.com/pages/conversions.html and they mention it at the bottom of the page. The reason for this type of adapter is that its quite a bit shorter than the advanced adapter and I think a little cheaper. Woody was making them a little while ago but I believe that his has stopped. If you do a search I believe that you can find more info on the swap.
JRS
JRS
Sorry, I think I was confusing Classic cruisers with Cool Cruisers.
What is the current $$$ for this one?
I think that I may have accidentally said Cool Cruisers at one point. Its actually Classic Cruisers. I called and I think they gave me a price of $475 or so for the 3spd T-case adapter. But don't quote me on that. You need a coarse 10 spline output shaft SM465 which I think someone told me that all pre 86 4x4 versions were.
The adapter is not the only piece you need, you also need the proper 203, or you will just have a spare adapter and no way to make it work with a 203..
The 203 you ned actualyl has a long female input, not like the mostly flushish ones that you typicaly see..
